Occasional "clicking" feeling felt through foot pegs
Hi Everyone,
Apologies if this is in the wrong area, but didn't know where to put it as it doesn't see to fit any other section.
Occasionally, more often at lower speeds, I can feel a "click" through the foot pegs. It's worse with the clutch lever out, than it is when I pull it in. I can just about feel it at higher constant speeds.
Chain adjustment seems OK and chain/rear sprocket looks good and wheel alignment looks good too.
Can I just unbolt the cover over the front sprocket cover and inspect it?
Any ideas as to what might be causing this "click" feeling?
I did a search, but found many questions but no real answers!
Thanks,
Andy.
Thanks,
Andy.
ScoldedCat- 2Silver
Number of posts : 195
Humour : This parrot is dead!
Re: Occasional "clicking" feeling felt through foot pegs
Two things I'd check first Andy,
Is the chain well lubed up with no tight spots etc, Then as you say pop the cover off & see if the front sprocket is tight, It may look it but can still 'nip up' a little, Cats are quite prone to this & my 'cat was awful if the adjustment wasn't kept spot on & well lubed, Good luck
Thanks Rob, I'll add it to my list of checks for tonight!
ScoldedCat- 2Silver
See if you can feel the 'click' whilst rotating the rear wheel with the bike on a stand.
As Nick has said the chain is the usual suspect and I've not always spotted a tight spot. Lets hope it is something as simple as that. The other reason I was getting unpleasant clicks was when the rear wheel bearing was about to collapse, but hopefully you can isolate the source by turning the wheel.
Number of posts : 5108
These quick jobs aren't! Left the bike half finished after it got too dark to see!
Front sprocket, rear sprocket, rear wheel bearings alignment and tension all good.
After removing the rear wheel I checked each link by hand and there is one stiff one, can just about move it by hand. No amount of oil and twiddling made it free up.
Could this be my problem?
ScoldedCat- 2Silver
It could be. If you lube the chain quite liberally the clicking could go away, that's only a short term fix if that is the case, but at least you know then that it is the chain.
You could try soaking the link in a small tub of oil overnight, You should be able to do this without removing the chain if the wheel is out. Apparently you shouldn't use WD40 as it can affect the seals inside the links.
Thanks guy's, I'll try soaking the troublesome link overnight.
I have an issue with WD-40 in that it's marketing is much better than the product! I only use oil to lubricate the chain anyway, so I'll try a good soaking and see if the "click" goes away.
I'm just relieved nothings going to drop off!
ScoldedCat- 2Silver
Took the bike for a spin tonight and it's no better. At least I didn't make it worse I suppose!
ScoldedCat- 2Silver
I had the same symptoms, a few weeks ago, it was hooked teeth on the front sprocket, £15 quid and 30 mins in the garage, = all sorted
Davie
Davie
furball- 3Gold
furball wrote:I had the same symptoms, a few weeks ago, it was hooked teeth on the front sprocket, £15 quid and 30 mins in the garage, = all sorted
Davie
Interesting you should say that, as it does seem to be more towards the front of the bike.
I'm thinking of just replacing the sprockets and chain in one go, especially as the chain has a stiff link and I don't know when they were last changed... peace of mind I suppose!
Hoping to have some time over the weekend to "tinker".
ScoldedCat- 2Silver
» Bikes you've owned / borrowed or felt like they were yous
» WoW 2022: Feeling Hot, Hot!!
» Foot rests
» god awful grinding feeling and somtimes a bit of a knock from what feels like inbetween my feet
» Clicking noise!
» Foot rests
» Clicking noise!
