custom dual high level exhaust
custom dual high level exhaust Empty custom dual high level exhaust
Post  grant26 Wed May 02 2012, 00:28
hi, bike isnt running right so selling it as a project (check other topic). Made out of stainless steel and was designed to take two danmoto exhaust so would take any two small-medium exhaust. Was made when I had my jack up kit on but I guss would work on normal set up if you hardened the shock ot removed mudguard.
Bad bits: I tacked it but gave it to my mate to weld, he made a mess of it and so needs grinding and rewelding.
Needs a reducer adding to create a seal onto the downpipe.
If you wanted equal pressure in each can you would need to add either a baffle or a slight block into the right hand can.
All the hard work has been done, measuring up the angles and tacking in place. Anyone could take this to a local welders to tidy up or even wrap in exhaust wrap. Really improves the look of the bike and is the only one in the world that i am aware of. I will add pics soon. Open to offers, Thanks
grant26
grant26
6Bronze
6Bronze
Number of posts : 53
Hobbies : Student at Lancaster Uni
Registration date : 2011-06-04
custom dual high level exhaust Empty Re: custom dual high level exhaust
Post  grant26 Sat May 12 2012, 20:30
on ebay [You must be registered and logged in to see this link.]
grant26
grant26
6Bronze
6Bronze
