a new rider!
a new rider!  Empty a new rider!
Post  Reuuk Fri Apr 01 2011, 10:30
hello guys and gals, My names Reu (roo) I'm 21 years old and i have my direct access test next week! :O really looking forward to getting myself on a thundercat!, There gorgeous!
I currently don't own one at this time but I'm going to view one on saturday Very Happy so hopefully Very Happy
hoping to find some information on here on what i should look out for when I'm viewing so i don't buy a bad one! and get some new friends from a different scene! (other than car)
Thanks looking forward to meeting you Very Happy
Reuuk
Reuuk
New Member
New Member
Number of posts : 2
Registration date : 2011-04-01
a new rider!  Empty Re: a new rider!
Post  yamahamad Fri Apr 01 2011, 12:47
Hi & welcome roo. Things to look for are rotted exhaust manifold, rusted swingarm & check the engine & chassis numbers are correct on the log book. Service history would be a plus but not essential if a diy mechanic has changed the oil at least. Generally see how it runs & sounds. If you do ride it check the gear change from 1st to 2nd it will be notchy but check it does not bang or grind. Paul.
Post  Guest Fri Apr 01 2011, 13:04
Welcome to the forum
Suzie haloangel
Post  Reuuk Fri Apr 01 2011, 13:04
Hi paul thanks for the information, Ill keep an eye out for those things, the one I'm going to look at is a 98 plate with 23k on the clock, Its garaged and used only in the summer (aparently) so hopefully won't be showing much signs of rust. I will most certainy be trying to have a test ride so Ill test out 1/2nd year allot more now you've mentioned that.
also I've been looking allot at acessories for the cats, the seat cowl? are they easy enough to get hold of?
Reu
Reuuk
Reuuk
New Member
New Member
Number of posts : 2
Post  0ldcat Fri Apr 01 2011, 14:03
Hello & Welcome to the Forum Reu (in danger of picking up the nick of Kanga ~ bet you've never heard that huh Rolling Eyes )
The site is littered with usefull hints, tips and info for you to search out and read. But if you cant find stuff post up in the lounge or relevant topic and someone will either answer or point you in the right direction.
With the second gear thingy ~ get the bike into second gear, then roll off the throttle, then, (and be bloody careful here), snap the throttle open again and hold it (hang on!!!). If you haven't got your licence or your not confident, get a mate to do this for you !!!
If the bike pops out of gear, this could possibly indicate a problem within the gearbox. You should seriously think of walking away or quite literally nocking a grand off the price of the bike, as that's roughly what it'll cost to put right.
It isn't a common problem, (as some may have you believe), but it is out there with some 'cats'.
In fact, in the 10 years of this site running, we've only had two occurrences and heard of two more. Stretchy can give you the details.
For after market accessories like seat cowls and the like, ~ ebay seems to have a fair amount of stuff ~ powerbronze & skidmarx did them too I believe.
Good luck with yer DAS and good hunting for your thundercat
Post  ellie Fri Apr 01 2011, 20:35
Welcome aboard!!
Ellie pinkelly
