nearly complete 99 'T' cat breaking for parts
ow3n
frosty
bm1957
woodstopher
Have a complete 99 thundercat broken for parts . Has been down the road hard, so the fairing is scuffed and cracked but should be repairable, the L/H case on the engine has a scuff, the usual for a low side. Have kept a couple of minor parts for my other 'cat but everything else is up for grabs. The Forks and rear shock are not included, reconditioning/upgrading them for use on the other. Engine has only 6k on it and was serviced the day before the accident (typical). Anyone need anything, message me with what your after. Not going to ask the world for anything, the missus isn't happy with the engine under the stairs so parts have to shift, and I got lucky with the new cat!!! Rear tyre (continental road attack) has less than 500 miles on it and is barely worn in the center (the writing in the middle of the tire has started to fade. about 0.5mm)
woodstopher- New Member
Number of posts : 3
Registration date : 2010-10-24
Re: nearly complete 99 'T' cat breaking for parts
Hi.woodstopher wrote:Have a complete 99 thundercat broken for parts . Has been down the road hard, so the fairing is scuffed and cracked but should be repairable, the L/H case on the engine has a scuff, the usual for a low side. Have kept a couple of minor parts for my other 'cat but everything else is up for grabs. The Forks and rear shock are not included, reconditioning/upgrading them for use on the other. Engine has only 6k on it and was serviced the day before the accident (typical). Anyone need anything, message me with what your after. Not going to ask the world for anything, the missus isn't happy with the engine under the stairs so parts have to shift, and I got lucky with the new cat!!! Rear tyre (continental road attack) has less than 500 miles on it and is barely worn in the center (the writing in the middle of the tire has started to fade. about 0.5mm)
Do you still have the sidestand? How much?
If you've got it, how much for the cut-off microswitch too?
Ben
bm1957- 5Bronze
Number of posts : 41
Registration date : 2010-02-21
Hi Ben, Have both, will work out postage and packing costs and you can have it for that.
Chris
Chris
Number of posts : 3
wouldnt have a seat cowl would you
Thamks Dave
Thamks Dave
frosty- 3Bronze
Number of posts : 29
Hobbies : hgv mechanic ,
Humour : peter kay
Registration date : 2010-06-05
Hi Chris
Sorry to hear of the lowside and damage to the bike. What happened?
Hope there was no damage to you.
I did less than 50 yds on a new rear tyre (0.00005mm wear possibly) into a lowside so you won't out embarrass me I hope.
Hope you get some sales to the needy on here.
How much would you want for the engine and box please? I'm finding a lot of false neutrals, how was yours riding?
ow3n- 2Bronze
Number of posts : 19
Registration date : 2010-08-11
ow3n wrote: I'm finding a lot of false neutrals
apologies for the topic deviation - have you changed your oil regularly and checked chain tension? My false neutrals went away after an oil change.
Number of posts : 5108
What kind of oil you using?
Are you going to be doing a rebuild? If so, then something to think about might be a factory pro shift kit, alot of people swear by Factory Pro shift kits. A new detent arm with bearings in it and a stronger spring, and depending on your bike a new shift star. I don't think the one on the Thundercat comes off the end of the selector drum, I can't remember.
This kind of thing.
Also, where in Bristol are you? Where do you go for a rideout?
Will be getting mine out again soon if you fancy meeting up for a blat somewhere.
This kind of thing.
Hey, thanks for the replies chaps. I don't know what oil is in there, I got a change right after I bought the bike. Or at least I asked for one, but the garage seemed a bit crap so who knows what went on...
TBH I'm not alllll that keen to drop a lot of money into the bike, I plan to sell it and get something a bit newer/faster some time soon. I suppose a new engine is probably on the serious side for a bike I plan to PX.
I'm just south of dursley, so I usually head over the cotswolds to oxfordshire-ish or to east wales.
Out of intrest, how was your blackbird? Do you have an opinion of it versus a comparable age/miles hayabusa?
stretchie_ wrote:What kind of oil you using?
This kind of thing.
ow3n- 2Bronze
Oh cool so you're either off to Foxy's Diner (or whatever it's called now), Fish Hill or Abergavenney normally??
I've got a few good rides around Brecons area if you fancy it sometime, got an all dayer or just a blat for a burger to Abergavveny and back can be good via Usk.
I've always just used Halfords oils in my 1.5l petrol Honda, 2.5 Diesel Discovery or my bikes and not had any problems so far, but was reading about oils recently and found out about JASO MA2 spec oil. Designed for wet clutches and to aid with grip for the clutch plates to promote good clutch engagement. So might try that next time, if you look around you can get it for £75 for 20 litres but it depends how much oil you go through really.
I'd do the cat up and keep it if I were you mate, it's the nut that connects the handlebars to the seat that makes it go faster, not just the engine.
My mates got a tatty old SV650 and he runs rings around everybody. It's bloody frustrating but good to watch.
As for the BlackBird mate I LOVE it. I've currently got:
- 2001 Fireblade 929. A mint bike less than 30k on the clock, just had a problem with the charging system but that's a common Honda problem so need to look into that and fix.
This bike ticks EVERY box for me, great for scratching, great two's up, great on short journeys, great on long journeys. It doesn't make you want to hoon everywhere but it will easily if you want to. My missus says it's the most comfortable bike she has ever been pillion on and she has done lot's of mileage on the back of several bikes, even more comfortable than the BlackBird she says. AND it's got LOADS of room under the seat for an alarm, chain, disklock, drink, sarnies and a packet of crisps.
- 1998 Blackbird. Tatty as hell, I bought it 2.5 years ago for £1,500 with full hard pannier set and it's currently got about 55k I think on it. Look them up these still go for between £2,000 - £3,000 now for a similar spec so that shows how tatty it is..... but it's still going . Get one, get one now.
Can't fault it, mine is a typical Sally Gunnel, not much to look at but a great runner. It can cruise nicely, VERY comfortable for me, especially with the corbin seat.
It'll hustle like a mutha too, totally different kind of power than the Blade. Put the throttle on and it'll shift, not as instant as the Blade, but keep the throttle wide open and at 7k revs it'll kick you in the arse and go in to warp speed.
You've got to put more thought into cornering though, it's got a long wheelbase and won't just tip it like the Blade will.
Campared to a busa? I've never ridden a Busa but in my narrow minded and uneducated view Busa's are for people on Visor down and who read Max Power and are the bike version of a Porshe. You've got to admire the engineering but there ugly as hell not my cup of tea I'm afraid, good engine for car projects though.
- 2001 Thundercat. My first bike and I'm going to keep it until I'm old and leave it to a grandson if I have one when I go. End of. I just love it.
Out of those I'm going to sell the Blade to fund some new tools, ride the BlackBird while I fix the Cat, then when the cat is together, I'll ride that while I strip and pretty up the BalckBird.
Chris,
I've lost the mounting bolts and nuts for the rear half of the front mudguard. (They also clamp the brake hoses) I've managed to bodge it but would you be willing to part with these? I'll pay the postage.
Cheers Rich.
Cheers Rich.
This argument doesn't work on me, I also want a porsche.stretchie_ wrote:Campared to a busa? I've never ridden a Busa but in my narrow minded and uneducated view Busa's are for people on Visor down and who read Max Power and are the bike version of a Porshe. You've got to admire the engineering but there ugly as hell not my cup of tea I'm afraid, good engine for car projects though.
ow3n- 2Bronze
ow3n wrote:This argument doesn't work on me, I also want a porsche.
There's just no hope for some people
Visor Down gone
Is it true that Visor Down has shut shop? Pity, I thought it was a good mag, but nothing like the epoch-making Performance Bikes circa the early to mid-1990s. Fast Bikes was a hoot too, but looked like it had been put together by a herd of rutting elk. Now they advocated 'hooning'.
zedhead- 2Bronze
Number of posts : 14
Registration date : 2011-01-21
I managed to low side mine as well, but part way through getting it going again.
I only need the the right wing mirror and the casing that sticks out on the right hand side throught the fairing, (I think its a started motor cover maybe). How much would you like for them if you still have them? thanks
Jefft- 1Bronze
Number of posts : 6
Registration date : 2011-02-20
Hi Chris,
Would you happen to have the original rear hugger?
Could you PM me please?
Ellie
Ellie
» Breaking the bike down for parts
» BREAKING PROJECT (SPECIAL PARTS), HERE'S A LINK TO - CHECK OUT OTHER ITEMS FOR SALE
» Complete Cat
» the bike makeover is almost complete
» Fuel Race Can Complete
» Complete Cat
